Zum Hauptinhalt wechseln
Sony Xperia XZ Premium Front Camera Replacement
Was du brauchst
  1. Sony Xperia XZ Premium Front Camera Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
    • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
    • Follow this guide for directions on using the iOpener.
  2. Sony Xperia XZ Premium Front Camera Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
  3. Sony Xperia XZ Premium Front Camera Replacement: Schritt 3, Bild 1 von 1
    • Take hold of the back panel with your fingers and remove.
  4. Sony Xperia XZ Premium Front Camera Replacement, Front Camera: Schritt 4, Bild 1 von 1
    • Remove the two bottom left 3.9 mm Phillips #000 screws.
  5. Sony Xperia XZ Premium Front Camera Replacement: Schritt 5, Bild 1 von 1
    • Insert the spudger under the bottom left frame and lift, try to lift vertically to wedge it out.
  6. Sony Xperia XZ Premium Front Camera Replacement: Schritt 6, Bild 1 von 1
    • Grab hold of the bottom left frame and lift out carefully.
  7. Sony Xperia XZ Premium Front Camera Replacement: Schritt 7, Bild 1 von 1
    • Insert a spudger under the tab above the camera and lift to disconnect it.
  8. Sony Xperia XZ Premium Front Camera Replacement: Schritt 8, Bild 1 von 1
    • Grab hold of the tab with your fingers.
  9. Sony Xperia XZ Premium Front Camera Replacement: Schritt 9, Bild 1 von 1
    • Lift the camera from the phone by the tab.
Abschluss
Cal Poly, Team S18-G2, Livingston Spring 2018 Mitglied von Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
5 Mitglieder
20 Anleitungen geschrieben
1 Kommentar zur Anleitung
The name of this tutorial is incorrect.
Gavin - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 52
Insgesamt: 2,503
