Einleitung
You will learn how to remove the motherboard from the Sony Xperia XZ Premium. This process includes unscrewing nine screws and removing the frame pieces. It is important to keep your work-space organized because there will be several pieces of the phone removed.
Was du brauchst
Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
Insert your nail under the top left connector and push to disconnect it.
Insert your nail under the metal tab of the connector above the battery and push to loosen it.
Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
Insert spudger in the gap above the battery and lift to loosen the motherboard.
Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
Grab hold of the motherboard with your fingers and lift it out of the phone gently.
5 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
Where do you buy a motherboard for the xz premium? thank you
If you know the name of the motherboard you can check on:
newegg.com
aliexpress.com
https://www.sony.com/electronics/support...
amazon.com
alibaba.com
