Einleitung
Also known as Xperia Z LT36i, Xperia C6603, Xperia C6602, Xperia Z LTE, Xperia Z HSPA+
How to change broken, not working Digitizer or Display.
This procedure is very hard. You must have experience to do this.
Ersatzteile
Einführungsvideo
Warm the Battery cover before disassemble it.
Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board.
This are: main Camera, front Camera and antenna wire Flex cable.
Now we can remove the Motherboard.
Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go.
All's well, that ends well. :)
Did you do it successfully?
76 weitere Nutzer haben diese Anleitung absolviert.
54 Kommentare
with a hairdryer for like 3 min on high
