Einleitung
The Battery of the phone can become worn with continued use. This guide will show you how to remove the Battery of Sony Xperia Z1 Compact.
Was du brauchst
Heat along the edges of the back cover using a heat gun to soften the glue.
Attach the small suction cup to the back cover near the bottom of the phone.
Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
Move the spudger around the edge of the back cover to separate it from the black adhesive.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
12 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
is there any reliable source for good replacement battery purchase?
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
