Einleitung
This guide will teach you how to replace the motherboard on your Sony Xperia Z1 Compact. If there are issues turning your phone on, follow the troubleshooting guide and if nothing else listed above this helps, then it may solve the problem.
Was du brauchst
Heat along the edges of the back cover using a heat gun to soften the glue.
Attach the small suction cup to the back cover near the bottom of the phone.
Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
Move the spudger around the edge of the back cover to separate it from the black adhesive.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
Remove the square rubber gasket from the camera using the plastic spudger.
Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
hi
Recently i brought Xperia Z1 now i am facing charging problem.
i already change new to battery but it is charging 75 % only.
after charging 75% my phone screen continually on and off
please let me know how can i fix this problem.
