Was du brauchst
If the glue is cooled down heat more. Don't force it.
If the screen works, remove the new screen and add the double sided tape
Now push town not to tight not to softly to the screen.
And that's it. You finished the screen replacement.
30 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Good video! Help me too! Thanks
There is a thin, soft foam layer on the backside of the factory screen assembly, right behind the LCD backlight. This insulation foam is missing from most replacement screens. It can be peeled off relatively easily, but it will not stick easily onto the replacement LCD. I am not sure whether it is required at all, does anybody have experience and recommendations concerning this?
My lcd burn before use Heat gun! Very sad!
Use t7000 glue for glueing screen back down,sure way of it not lifting off
