Einleitung
Sony Xperia Z2 (D6502, D6503, and D6543) - How to disassemble the phone and replace the Earpiece.
Please SUBSCRIBE to my channel ツ
Werkzeuge
Kein Werkzeug erforderlich.
Einführungsvideo
  1. Switch off the phone. If you can't switch it off, you can use the OFF button near to the SIM card Tray. Warm the Back Cover. You can use a hairdryer.
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Use a small suction cup and plastic tools for separating the Rear panel. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape). Please SUBSCRIBE to my channel  ツ
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
    • Please SUBSCRIBE to my channel ツ
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Disconnect the Battery Flex Cable and remove the two Philips screws. Li-Polymer Battery, 3.8V, 3200mAh Part number: LIS1543ERPC
  6. Disconnect one by one: Magnetic Charging Dock Flex Cable
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
  7. Took the Logic Board, making it pick up first on the left side Be careful not to tear up a cable. .
  8. Earpiece
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
ZFix
162.957 Reputation
304 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
281 Mitglieder
792 Anleitungen geschrieben
Would be nice with a comment on how to remove the earpiece.
Since the phone is waterresistance the headjack and earpiece are taped to the body which makes that you need to buy a new sparepart, but look out on ebay that you get a part with tape to it.
Claes - Antwort
After having done the removal of the earpiece you will have to, either buy a new adhesive for the earpice or a new earpiece. But be aware some spareparts are sold without adhesive.
Claes -
I accidentally torn apart one of the cables( vibrate cable:the brown one) I'm messed up! Vibration not working. What can I do? Where can I buy one of those cables? Please reply!
Mahtab - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 43
Insgesamt: 6,625
