Zum Hauptinhalt wechseln
Sony Xperia Z2 Logic Board Replacement
Was du brauchst
Einführungsvideo
  1. Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: Schritt 1, Bild 1 von 3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: Schritt 1, Bild 2 von 3 Sony Xperia Z2 Logic Board Replacement, Rear / Battery Cover: Schritt 1, Bild 3 von 3
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Logic Board Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Z2 Logic Board Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Z2 Logic Board Replacement: Schritt 2, Bild 3 von 3
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Logic Board Replacement: Schritt 3, Bild 1 von 2 Sony Xperia Z2 Logic Board Replacement: Schritt 3, Bild 2 von 2
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  4. Sony Xperia Z2 Logic Board Replacement, Battery: Schritt 4, Bild 1 von 3 Sony Xperia Z2 Logic Board Replacement, Battery: Schritt 4, Bild 2 von 3 Sony Xperia Z2 Logic Board Replacement, Battery: Schritt 4, Bild 3 von 3
  5. Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: Schritt 5, Bild 1 von 3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: Schritt 5, Bild 2 von 3 Sony Xperia Z2 Logic Board Replacement, Wi-Fi Antenna: Schritt 5, Bild 3 von 3
    • Unscrew the screw and remove the Wi-Fi Antenna.
  6. Sony Xperia Z2 Logic Board Replacement, Logic Board: Schritt 6, Bild 1 von 2 Sony Xperia Z2 Logic Board Replacement, Logic Board: Schritt 6, Bild 2 von 2
    • Disconnect one by one:
    • Magnetic Charging Dock Flex Cable
    • Volume / Power Button and Microphone Flex Cable
    • Main Camera
    • Audio Jack and Light Sensor Flex cable
    • Coaxial Antenna Cable
  7. Sony Xperia Z2 Logic Board Replacement: Schritt 7, Bild 1 von 3 Sony Xperia Z2 Logic Board Replacement: Schritt 7, Bild 2 von 3 Sony Xperia Z2 Logic Board Replacement: Schritt 7, Bild 3 von 3
Abschluss
19 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.308 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.535 Anleitungen geschrieben
3 Kommentare
Hi
Do anyone knows where I can buy a logic board for Xperia Z2?
Johannes Stockinger - Antwort
https://www.ebay.com/sch/i.html?_from=R4...
or I bought there
https://ru.aliexpress.com/wholesale?catI...
be careful to find cheaper price and for your model D6503 or D6563…
Alexander -
Are you sure Phillips #00 is the correct size of screwdriver? I had difficulty getting one of the screws to turn (the screwdriver kept slipping), so I tried the other sizes in my iOpener Kit and found that the PH#000 seemed to fit them better, and that screw came straight out with it.
Edward Millen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 18,522
