Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Remove the main flex cable from the Sony Xperia Z3 Compact motherboard. This includes the button cable.
  1. First, heat up. And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover. Finally, remove the back cover.
    • First, heat up.
    • And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
    • Finally, remove the back cover.
  2. Disconnect the NFC antenna. Unscrew the screws holding the black midframe in place. Remove back frame.
    • Disconnect the NFC antenna.
    • Unscrew the screws holding the black midframe in place.
    • Remove back frame.
  3. Disconnect the battery flex cable.
    • Disconnect the battery flex cable.
  4. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  5. Remove rear camera bracket. Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows. Remove rear camera.
    • Remove rear camera bracket.
    • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
    • Remove rear camera.
  6. Release connectors and screw. Release connectors and screw. Release connectors and screw.
    • Release connectors and screw.
  7. Remove motherboard. Remove motherboard. Remove motherboard.
    • Remove motherboard.
  8. Remove main flex. Remove main flex. Remove main flex.
    • Remove main flex.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Sophia
42.794 Reputation
62 Anleitungen geschrieben
hi dear
my mobile (sony xperia z3 mini ) it problem in screen, i changed screen but still not work always black how can i do to fixed my mobile ???? plz help me
BR
Swren
swren1987 - Antwort
I can not loosen a screw, what can I do?
Piero Sabino - Antwort
Hey Fixit, I will repair my Wifi, but I can not find the component parts on the mainboard on the Z3c
Have a description where is the wifi component similar to these video because on the Z3Compact?
http://www.youtube.com/watch?v=dvq1zkiu4...
Sofie - Antwort
is there label imei or meid in it ???
Ardians Faqih - Antwort
Yes, there is a label in the phone with IMEI info. For some reason, it’s not show on the pictures, but you can see the label simply by opening the bottom port cover on the left side of the phone and pulling on it. The IMEI is the number written on the top right of the label.
axel -
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 10
Letzten 30 Tage: 36
Insgesamt: 16,086
