Einleitung
This guide shows you how easy to replace Sony Xperia Z3 back cover. And if the phone waterproof or not depends not only perfect operation but also the good back cover replacement parts.
Einführungsvideo
  1. Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
    • Heat the back cover for about 1 to 2 minutes until you feel the adhesive sticker is soften a lot.
  2. Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
    • Place the suction cup on top part or bottom part which you think is easy to carry and open a gap.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Insert guitar pick into the gap and slide to cut the sticker around the back cover.
    • Insert guitar pick into the gap and slide to cut the sticker around the back cover.
  5. Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
    • Especially the left side, you'd better handle as the direction we marked or you are likely to break the flex cable on the left bottom corner.
  6. Remove the back cover easily. It comes with camera lens and NFC.
    • Remove the back cover easily. It comes with camera lens and NFC.
    • And you can place your new back cover, press the adhesive sticker and done the replacement.
Abschluss
12 weitere Nutzer haben diese Anleitung absolviert.
Sophia
41.395 Reputation
62 Anleitungen geschrieben
My Xperia z3 was broken back cover if I replace this cover, this waterproof features are still working or not? guys I need your suggestions
Winstonmary Dimagnaong - Antwort
Are you sure that the replacement parts mentioned above would work for the Z3 DUAL as well? I believe it has a slightly different size or shape compared to the regular Z3
Shevek - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 35
Insgesamt: 20,460
