Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This is the replace guide for Sony Xperia Z3 Dual as well as Sony Xperia Z3 earpiece speaker.
  1. Power off and remove two SIM card trays at first before earpiece speaker replacement.
    • Power off and remove two SIM card trays at first before earpiece speaker replacement.
  2. Heat to soften back cover adhesive sticker. Use suction cup to open a gap and insert into the guitar pick. Slide guitar pick to cut the sticker.
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide guitar pick to cut the sticker.
  3. Remove back cover.
    • Remove back cover.
  4. It's easy to remove the battery. It's easy to remove the battery. It's easy to remove the battery.
    • It's easy to remove the battery.
  5. Twist off two screws at first.
    • Twist off two screws at first.
  6. Remove three pieces of securing bracket. Remove three pieces of securing bracket. Remove three pieces of securing bracket.
    • Remove three pieces of securing bracket.
  7. Release all the connectors connecting with motherboard. Pry motherboard up from left side. It's really hold tightly by some hidden keys, so be careful. Remove motherboard.
    • Release all the connectors connecting with motherboard.
    • Pry motherboard up from left side. It's really hold tightly by some hidden keys, so be careful.
    • Remove motherboard.
  8. Remove the blocker beside earpiece speaker and you can see the breakout to pry up the speaker. Remove earpiece speaker finally. Remove earpiece speaker finally.
    • Remove the blocker beside earpiece speaker and you can see the breakout to pry up the speaker.
    • Remove earpiece speaker finally.
Abschluss
13 weitere Nutzer haben diese Anleitung absolviert.
Sophia
43.297 Reputation
62 Anleitungen geschrieben
Thanks for the guide, it worked very well.
Maybe it's worth mentioning that there's a sticker at the back of the battery and you shouldn't be afraid to just pull the battery out.
Steven Kolenberg - Antwort
Hai. Can you give me the link to buy the earpiece? Tq
Wafi Sams - Antwort
Thanks for the guide, however my ear piece speaker now rattles when i play music at medium levels. I have tried installing additional adhesive to it, but still cracks.
Tony Ho - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 15,846
