Einleitung
This is the replacement guide for Sony Xperia Z3 Dual as well as Sony Xperia Z3 front camera.
  1. Power off the phone and remove two SIM card trays before replacement.
    • Power off the phone and remove two SIM card trays before replacement.
  2. Heat to soften back cover adhesive sticker.
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick. Slide the guitar pick to cut the sticker.
    • Remove back cover carefully and avoid cracking the glass.
    • Remove battery or not is optional. Remove it makes the replacement convenient while keep it also will not block the replacement.
    • Remove screws at first.
    • Remove three pieces of securing bracket.
    • Release all the connectors connecting with motherboard.
    • Pry the motherboard up from left side and remove it. The motherboard is hold tightly by some hidden keys, so you should be very careful.
    • Release the connector and pull out the flex at first, please be careful as you can.
    • Remove the front camera finally.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Sophia
Mitglied seit 25.03.2014
41.189 Reputation
62 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 2,119
