Zum Hauptinhalt wechseln
Sony Xperia Z3 Dual Headphone Jack Replacement
Was du brauchst
  1. Sony Xperia Z3 Dual Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 1
    • Power off the phone and remove two SIM card trays before headphone jack replacement.
  2. Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 2, Bild 3 von 3
    • Heat to soften back cover adhesive sticker.
    • Use suction cup to open a gap and insert into the guitar pick.
    • Slide the guitar pick to cut the sticker all around every side.
  3. Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 3, Bild 1 von 1
    • Remove back cover.
  4. Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 4, Bild 1 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 4, Bild 2 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 4, Bild 3 von 3
    • Remove battery easily.
  5. Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Twist off two screws by Philips screwdriver at first.
  6. Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 6, Bild 1 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 6, Bild 2 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 6, Bild 3 von 3
    • Remove three pieces of securing bracket.
  7. Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 7, Bild 1 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 7, Bild 2 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 7, Bild 3 von 3
    • Release all the connectors connecting with motherboard.
    • Pry it up from left side. Please be careful with some hidden keys, they held the motherboard really tightly.
  8. Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 8, Bild 1 von 2 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 8, Bild 2 von 2
    • Remove securing cover beside headphone jack.
  9. Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 9, Bild 1 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 9, Bild 2 von 3 Sony Xperia Z3 Dual Headphone Jack Replacement: Schritt 9, Bild 3 von 3
    • Remove the flex cover on the headphone jack. It's a part of the assembly and comes with denoise MIC and sensors.
    • Cut the adhesive sticker between headphone jack and midframe.
    • Remove headphone jack finally.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Sophia
43.708 Reputation
62 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 6,932
