Einleitung
This is the replace guide for Sony Xperia Z3 Dual as well as Z3 loudspeaker assembly.
Einführungsvideo
  1. Heat to soften back cover sticker. Place the suction cup and try to open a gap. Insert the guitar pick into the gap.
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Slide the guitar pick to cut the sticker and remove the back cover. Slide the guitar pick to cut the sticker and remove the back cover.
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove two screws by Philips screwdriver. Release all the connectors connecting with loudspeaker assembly. Remove the small vibrator securing bracket.
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  5. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it. Remove the securing cover. It's thin and weak, please be careful when remove it.
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  6. Pry up the assembly and carry it out. Pry up the assembly and carry it out. Pry up the assembly and carry it out.
    • Pry up the assembly and carry it out.
  7. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly. Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Sophia
41.565 Reputation
62 Anleitungen geschrieben
this is all good but is there a link to the part ?
morten hundevad - Antwort
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 3,856
