Zum Hauptinhalt wechseln
Sony Xperia Z3 Dual Loudspeaker Assembly Replacement
Was du brauchst
Einführungsvideo
  1. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: Schritt 1, Bild 1 von 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: Schritt 1, Bild 2 von 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: Schritt 1, Bild 3 von 3
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 2, Bild 1 von 2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 2, Bild 2 von 2
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 3, Bild 1 von 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 3, Bild 2 von 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 3, Bild 3 von 3
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 4, Bild 1 von 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 4, Bild 2 von 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 4, Bild 3 von 3
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 5, Bild 1 von 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 5, Bild 2 von 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 5, Bild 3 von 3
    • Pry up the assembly and carry it out.
  6. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 6, Bild 1 von 2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: Schritt 6, Bild 2 von 2
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Sophia
43.735 Reputation
62 Anleitungen geschrieben
2 Kommentare
this is all good but is there a link to the part ?
morten hundevad - Antwort
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 7
Insgesamt: 4,323
