Zum Hauptinhalt wechseln
Sony Xperia Z3 USB cover and SD card slot cover Replacement
Einführungsvideo
Sony Xperia Z3 USB Port Cover + SD/SIM Flap Replacement
  1. Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: Schritt 1, Bild 1 von 3 Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: Schritt 1, Bild 2 von 3 Sony Xperia Z3 USB cover and SD card slot cover Replacement, USB cover and SD card slot cover: Schritt 1, Bild 3 von 3
    • Use your fingers to pull firmly on the broken USB port cover until it pops out.
    • Remove the USB port cover.
  2. Sony Xperia Z3 USB cover and SD card slot cover Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Z3 USB cover and SD card slot cover Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Z3 USB cover and SD card slot cover Replacement: Schritt 2, Bild 3 von 3
    • Use your fingers to firmly pull out the SD/SIM card flap.
    • Remove the SD/SIM card flap.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Sophia
43.810 Reputation
62 Anleitungen geschrieben
4 Kommentare
Does Z3 and Z3V have same size USB flaps?
Sudip Shrestha - Antwort
i need for model D6633
Umer Farooq -
ineed both same size
Umer Farooq -
Part of the white plastic end connected to the old USB charge port cover flap on my Sony XperiaZ3v is still inside my phone. How do I get that broken piece out of the phone before installing the new USB cover in the phone?
Narda Dawidowicz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 44
Insgesamt: 21,086
