Zum Hauptinhalt wechseln
Sony Xperia Z5 Charging Port Flex Replacement
Was du brauchst
  1. Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: Schritt 1, Bild 1 von 2 Sony Xperia Z5 Charging Port Flex Replacement, Charging Port Flex: Schritt 1, Bild 2 von 2
    • Remove SIM card tray.
  2. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 2, Bild 1 von 2 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 2, Bild 2 von 2
    • Heat the back cover to soften the adhesive sticker.
    • Place the suction cup and inert metal opening tool to open a gap from top side.
  3. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 3, Bild 1 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 3, Bild 2 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 3, Bild 3 von 3
    • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
    • Remove back cover.
  4. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 4, Bild 1 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 4, Bild 2 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 4, Bild 3 von 3
    • Release battery connector and pull off the adhesive tape underneath.
    • Pry up battery.
  5. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 5, Bild 1 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 5, Bild 2 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 5, Bild 3 von 3
    • Release rear camera connector, front camera connector, audio jack flex connector and main flex connector on the motherboard and remove the screws there.
    • Take away the plastic bracket.
  6. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 6, Bild 1 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 6, Bild 2 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 6, Bild 3 von 3
    • Remove metal cover securing loudspeaker and twist off screws.
    • Pry up and loosen the bottom side of main flex assembly.
  7. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 7, Bild 1 von 2 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 7, Bild 2 von 2
    • Remove main flex. ( Attention: the fingerprint sensor connector is here, be careful to loosen it)
  8. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 8, Bild 1 von 2 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 8, Bild 2 von 2
    • This is main flex assembly. (It comes with loudspeaker and vibration motor )
  9. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 9, Bild 1 von 2 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 9, Bild 2 von 2
    • Remove rear camera.
  10. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 10, Bild 1 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 10, Bild 2 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 10, Bild 3 von 3
    • Remove that securing bracket, then remove front camera.
  11. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 11, Bild 1 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 11, Bild 2 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 11, Bild 3 von 3
    • Release connectors on the motherboard. Remove motherboard.
  12. Sony Xperia Z5 Charging Port Flex Replacement: Schritt 12, Bild 1 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 12, Bild 2 von 3 Sony Xperia Z5 Charging Port Flex Replacement: Schritt 12, Bild 3 von 3
    • Remove charging port flex.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Lenka
2.376 Reputation
6 Anleitungen geschrieben
3 Kommentare
How about the waterproof adhesive ?
Tess - Antwort
Would you have a step by step method to replace it ?
Tess - Antwort
I can’t turn my phone back on. Any clues?
Bjoern Aeschlimann - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 17,506
