Zum Hauptinhalt wechseln
Sony Xperia Z5 Compact Motherboard Replacement
Was du brauchst
  1. Sony Xperia Z5 Compact Motherboard Replacement, Charging port flex: Schritt 1, Bild 1 von 2 Sony Xperia Z5 Compact Motherboard Replacement, Charging port flex: Schritt 1, Bild 2 von 2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 3, Bild 1 von 2 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove all 10 Phillips screws.
    • Disconnect NFC clip and flashlight clip.
  4. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 4, Bild 1 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 4, Bild 2 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 5, Bild 1 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 5, Bild 2 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove front camera.
  6. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 6, Bild 1 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 6, Bild 2 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Remove rear camera.
  7. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 7, Bild 1 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 7, Bild 2 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove loudspeaker.
  8. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 8, Bild 1 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 8, Bild 2 von 3 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove charging port flex.
  10. Sony Xperia Z5 Compact Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 2 Sony Xperia Z5 Compact Motherboard Replacement, Motherboard: Schritt 10, Bild 2 von 2
    • Remove the motherboard/battery assembly.
    • Using a spudger, release the battery connector from the motherboard.
  11. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 11, Bild 1 von 2 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Slowly pull out the two battery tapes located on the right side of the battery.
    • Remove the battery from the motherboard.
  12. Sony Xperia Z5 Compact Motherboard Replacement: Schritt 12, Bild 1 von 2 Sony Xperia Z5 Compact Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Place two pieces of binding tape on the center of the motherboard.
    • Reattach the battery to the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,175
