Einleitung
If your Sony Xperia Z5 Compact fails to charge or sync data, you may need to change new charging port flex. Here is the process to replace the USB board.
Heat up the back cover to soften the adhesive.
Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
Remove back cover.
Release charging port connector.
Remove plastic protective bar.
Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
9 weitere Nutzer haben diese Anleitung absolviert.
4 Kommentare
Hi great guide thank you, made it less daunting than I expected to repair my own phone, and cheaper than getting it repaired by someone else! Phone is as good as new, though I could probably do with some new adhesive, as the guitar picks mess it up a fair bit. You did mention including adhesive though so fair play!
@bernhard you don’t need to reseal anything apart from the back, although the camera flash does have a small amount of adhesive behind it when you lift that part up, though doesn’t seem to be messed up too much
