Einleitung
Use this guide to replace the volume and power button on your Sony Xperia ZL. You will need a plastic prying tool and a JIS #00 Screwdriver. This guide is useful if your power button stops working. It can also be used to replace the volume buttons. Make sure the phone is completely powered off before starting.
Was du brauchst
Open the small cover on the bottom of the rear cover.
Peel back the sticker under the cover to reveal two screws.
Remove the two JIS #00 screws from the back of the phone.
Peel the sticker back to get access of the connector and use a nylon spudger to disconnect it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
