Zum Hauptinhalt wechseln
Sony Xperia ZL Volume and Power Button Replacement
Was du brauchst
  1. Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: Schritt 1, Bild 1 von 2 Sony Xperia ZL Volume and Power Button Replacement, Volume and Power Button: Schritt 1, Bild 2 von 2
    • Open the small cover on the bottom of the rear cover.
    • Peel back the sticker under the cover to reveal two screws.
    • Remove the two JIS #00 screws from the back of the phone.
  2. Sony Xperia ZL Volume and Power Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the six screws from the phone using a JIS #00 screwdriver.
  3. Sony Xperia ZL Volume and Power Button Replacement: Schritt 3, Bild 1 von 1
    • Use a nylon spudger to disconnect the seven connectors.
    • Never use a metal spudger around the battery. Use plastic or nylon prying tools instead.
  4. Sony Xperia ZL Volume and Power Button Replacement: Schritt 4, Bild 1 von 1
    • The last connector is located under the back sticker.
    • Peel the sticker back to get access of the connector and use a nylon spudger to disconnect it.
  5. Sony Xperia ZL Volume and Power Button Replacement: Schritt 5, Bild 1 von 1
    • Remove the camera assembly using an opening tool or spudger.
  6. Sony Xperia ZL Volume and Power Button Replacement: Schritt 6, Bild 1 von 1
    • Remove the motherboard with an opening tool or spudger.
  7. Sony Xperia ZL Volume and Power Button Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery with a plastic opening tool or spudger.
    • The battery has adhesive tape that connects it to the phone which makes it difficult to pry out.
    • Never use metal prying tools on the battery. Be sure to use a plastic prying tool to avoid puncturing the battery.
  8. Sony Xperia ZL Volume and Power Button Replacement: Schritt 8, Bild 1 von 1
    • Detach the plastic covering from the top side of the phone by hand.
  9. Sony Xperia ZL Volume and Power Button Replacement: Schritt 9, Bild 1 von 1
    • Pry off the signal receptor and front camera using an opening tool or spudger.
    • The signal receptor has adhesive tape underneath so proceed with caution when prying.
  10. Sony Xperia ZL Volume and Power Button Replacement: Schritt 10, Bild 1 von 1
    • Remove the volume and power button with an opening tool or spudger.
    • For replacement, this component comes as a whole. If the volume and power button do not work, they will need to be replaced together.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Liam Kanaley
433 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 Mitglied von UMass Dartmouth, Team 1-7, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 2,070
