Zum Hauptinhalt wechseln
Sony Xplod CDX-MP30 Front Screen Motherboard Replacement
Was du brauchst
  1. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: Schritt 1, Bild 1 von 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: Schritt 1, Bild 2 von 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Panel: Schritt 1, Bild 3 von 3
    • Press down the release button on the bottom left corner of the face plate.
    • Then remove the face plate carefully.
  2. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement, Front Screen Motherboard: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Phillips #0 Screwdriver
    $5.49
    Kaufen
  3. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 3, Bild 1 von 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 3, Bild 2 von 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use two fingers to create a small gap in the top of the faceplate, as indicated in the picture.
  4. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 4, Bild 1 von 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 4, Bild 2 von 3 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 4, Bild 3 von 3
    Heavy-Duty Spudger
    Kaufen
    • Insert the flat end of the Heavy-duty Spudger into the opening you created.
    • Slide it to the right carefully, until you feel the screen pop off.
    • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
  5. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 5, Bild 1 von 2 Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
  6. Sony Xplod CDX-MP30 Front Screen Motherboard Replacement: Schritt 6, Bild 1 von 1
    • To remove the LCD, please refer to the iFixit soldering guide.
    • Once the LCD screen is removed, you have unrestricted access to the front screen motherboard.
Abschluss
Chao Chen
79 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 5-35, Amido Fall 2011 Mitglied von Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 5,597
