Zum Hauptinhalt wechseln
Sony a7 Battery Replacement
  1. Sony a7 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the camera upside down, and observe where the battery door and switch are located on the camera.
    • This replacement guide is using a cardboard and tape placeholder to simulate the battery, battery door, and switch.
  2. Sony a7 Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide the switch over to the right side to open the battery door.
  3. Sony a7 Battery Replacement: Schritt 3, Bild 1 von 1
    • Depress the blue lever to allow the battery to pop out slightly.
  4. Sony a7 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the camera.
    • Make sure to hold onto the battery firmly when removing it from the camera, as it could slide out and fall.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 54
Insgesamt: 2,183
