Einleitung
This is a pre-requisite list of steps that will act as a placeholder for all other applicable guides pertaining to the Sony a7.
Was du brauchst
Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
