Einleitung
This guide is to show how you would replace your battery if it is malfunctioning. This guide will show you how to take off the back cover of your tablet, disconnect the wires from the logic board, and remove the battery from the tablet.
Ersatzteile
Keine Ersatzteile angegeben.
Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
2 weitere Nutzer haben diese Anleitung absolviert.
