Einleitung
This guide will show you how to remove the screen of the tablet if the screen is broken or cracked.
Was du brauchst
Take off the screen protector and the screen on the tablet.
Wedge a plastic opening tool between the screen protector and the screen.
Using leverage, move the tool around the entire front face of the tablet in order to break the adhesion.
Continue until the top screen protector pops off.
Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
Remove the tape covering the ribbon cable's (which connects to the front of the screen) insertion point on the back of the device.
Remove the ribbon cable by placing your fingers on the outside of the ribbon closest to the port it goes into.
Flip the black switch up so the ribbon cable will be able to come out.
Gently pull the ribbon cable out of the port.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Where to buy a replacement screen for a azpen A848 projector tablet
