Zum Hauptinhalt wechseln
iBook G3 Clamshell Keyboard Replacement
Was du brauchst
  1. iBook G3 Clamshell Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell Keyboard Replacement, Airport Card: Schritt 2, Bild 1 von 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
    • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
  3. iBook G3 Clamshell Keyboard Replacement: Schritt 3, Bild 1 von 1
    • If your computer does not have an airport card, you can skip the next two steps.
    • Grasp the clear plastic tab on the airport card and pull up and toward the display.
  4. iBook G3 Clamshell Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Hold the airport card in one hand and use your other hand to remove the antenna cable.
  5. iBook G3 Clamshell Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove the two Phillips screws that secure the RAM shield.
  6. iBook G3 Clamshell Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
  7. iBook G3 Clamshell Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Pull up the keyboard connector cable by its clear plastic loop.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Angehängte Dokumente
iRobot
1 Reputation
636 Anleitungen geschrieben
Ein Kommentar
I was worried about replacing the key board having never worked on a laptop before, your guide was a great help! Thank you, Dave
dave - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 9,420
