Einleitung
Follow this guide to use a spark tester to test the ignition system on a 2019 Echo Power Pruner model PPT-2620.
This procedure requires two people.
Was du brauchst
Use a T27 Torx screwdriver to remove the two screws securing the bottom of the muffler cover to the motor.
Tilt the muffler cover up, hinging along the top edge, until it can be removed from the motor cover.
Remove the muffler cover.
Connect the spark plug boot to the left terminal of the ignition checker.
Connect the ignition checker alligator clip to a metal surface on the motor to ground the accessory cord.
Set the spark gap to 6 mm by turning the spark gap adjustment knob counterclockwise.
Watch for a spark in the spark window while a second person pulls the starter to crank the engine.
Consult the ignition checker instruction manual to troubleshoot the device.
