Zum Hauptinhalt wechseln
Speaker Bose SoundDock Motherboard Replacement
Was du brauchst
  1. Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: Schritt 1, Bild 1 von 2 Speaker Bose SoundDock Motherboard Replacement, Bose SoundDock Motherboard: Schritt 1, Bild 2 von 2
    • Remove the battery by pressing your finger down on the center button and twisting it counter-clockwise.
    • Remove battery and set it aside.
  2. Speaker Bose SoundDock Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic scraper to remove the rubber gasket from the bottom of speaker system and set it aside.
  3. Speaker Bose SoundDock Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use a standard sized Phillips Screwdriver to remove the four screws on the bottom of the speaker system.
  4. Speaker Bose SoundDock Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Using a smaller flat head screw driver, unscrew the semi-circle plate from bottom to expose the motherboard.
    • Once the components are unscrewed, the plastic dock frame may fall out.
  5. Speaker Bose SoundDock Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Gently pull both ribbon cables out of the motherboard.
  6. Speaker Bose SoundDock Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Replace it with new motherboard by plugging in the thinner wire into the small slot, and the larger wire into the wider slot.
    • Reverse steps 1 through 4 to reassemble dock.
Abschluss
Dalton Alexandre
123 Reputation
1 Anleitung geschrieben
Cal Poly, Team 24-5, Green Winter 2015 Mitglied von Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Where can you buy the motherboard?
Steffen Jensen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 3,276
