Einleitung
This guide will illustrate how to easily replace the motherboard on the Sphero Ollie with only your hands, Plastic Opening Tool and a Phillips-Head Screwdriver.
Was du brauchst
Firmly grasp Ollie in one hand.
Remove the blue rubber tire in a peeling motion with your opposite hand.
Continue to firmly hold Ollie in one hand.
Use a Plastic Opening Tool to gently pry off the hubcap.
Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
Remove the plastic tire frame from the device
Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
Loosen and remove the 10mm screws holding the antenna to the case.
Gently remove mother board from the case with an upward motion.
2 weitere Personen haben diese Anleitung absolviert.
