Zum Hauptinhalt wechseln
Spin Master Boxer Remote Trigger Buttons Replacement
Was du brauchst
  1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: Schritt 1, Bild 1 von 1
    • Lay the remote flat on your work space, with joysticks facing you.
  2. Spin Master Boxer Remote Trigger Buttons Replacement: Schritt 2, Bild 1 von 1
    • Remove both joysticks by gripping under circular knob and gently pulling towards you.
    • The joysticks should detach without much effort.
  3. Spin Master Boxer Remote Trigger Buttons Replacement: Schritt 3, Bild 1 von 1
    • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
    • Remove the batteries from the remote and set it to side.
    • Use the same screwdriver to remove all four 4mm screws on back panel.
  4. Spin Master Boxer Remote Trigger Buttons Replacement: Schritt 4, Bild 1 von 2 Spin Master Boxer Remote Trigger Buttons Replacement: Schritt 4, Bild 2 von 2
    • Insert the Jimmy in between the top panel and the bottom panel.
    • Gently use the Jimmy to separate both plastic panels from each other.
    • Pull the panels apart and set bottom piece on workbench.
  5. Spin Master Boxer Remote Trigger Buttons Replacement: Schritt 5, Bild 1 von 2 Spin Master Boxer Remote Trigger Buttons Replacement: Schritt 5, Bild 2 von 2
    • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
    • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
Abschluss
Lauren Roide
739 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G1, Maness Spring 2019 Mitglied von Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 856
