Einleitung
If Spin Master Boxer’s screen is cracked, follow this step by step guide to replace it. You will need a Size 00 Philips Screwdriver to complete guide.
Was du brauchst
Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
