Zum Hauptinhalt wechseln
Spin Master Boxer Wheel Gears Replacement
Was du brauchst
  1. Spin Master Boxer Wheel Gears Replacement, Robot Screen: Schritt 1, Bild 1 von 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Wheel Gears Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Wheel Gears Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Wheel Gears Replacement: Schritt 4, Bild 1 von 2 Spin Master Boxer Wheel Gears Replacement: Schritt 4, Bild 2 von 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Wheel Gears Replacement: Schritt 5, Bild 1 von 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Wheel Gears Replacement, Robot Wheel Gears: Schritt 6, Bild 1 von 1
    • Place robot on back so that the sensors are facing up.
  7. Spin Master Boxer Wheel Gears Replacement: Schritt 7, Bild 1 von 2 Spin Master Boxer Wheel Gears Replacement: Schritt 7, Bild 2 von 2
    • Gently separate the left set of wheels from the inner portion of the circuit board, by gripping the wheels and pulling them away from main body of robot.
    • There are wires attached to each set of wheels, so be careful not to rip them apart.
    • Repeat the process for the right set of wheels.
  8. Spin Master Boxer Wheel Gears Replacement: Schritt 8, Bild 1 von 2 Spin Master Boxer Wheel Gears Replacement: Schritt 8, Bild 2 von 2
    • Use the Phillips #00 Screwdriver to remove the 3mm screw that connect the black wheels to the gears.
    • You will have to go through the black wheel to unscrew some of the screws.
  9. Spin Master Boxer Wheel Gears Replacement: Schritt 9, Bild 1 von 3 Spin Master Boxer Wheel Gears Replacement: Schritt 9, Bild 2 von 3 Spin Master Boxer Wheel Gears Replacement: Schritt 9, Bild 3 von 3
    • Grip wheel, and gently pull up, to separate white gear casing into its front and back panel.
  10. Spin Master Boxer Wheel Gears Replacement: Schritt 10, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, grip defective gear, and pull up and out of gear system to replace.
Abschluss
Lauren Roide
739 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G1, Maness Spring 2019 Mitglied von Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
This is super useful guide and picture are clear for the steps. Will be excellent to know where to buy these gears replacements?
Javier Perez - Antwort
Hello. Thé motor seems to be broken. Do you Knowles ils spec to buy à New one.
Sorry, im french...
Tanks.
Jerome Carbonneaux - Antwort
Do you know its spec to buy a new one?
Realy sorry...
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 33
Insgesamt: 3,700
