Einleitung
Toys go through a lot, and many times they get dirty. This guide will show you how to remove the fur for further cleaning or full replacement.
Was du brauchst
Use the spudger tool to push up on the black clip to free it.
Pull the clip out.
Lift fur up to reveal the next set of clips.
Insert a spudger to push up on the black clip to free it.
Pull out the clip.
Lift the fur up and over the Hatchimals Head.
Remove the six 12mm Phillips #00 screws from then body.
Remove the three 7mm Phillips #00 screws from the head.
Remove the wheel base and the circuit board carefully not to damage the spring.
Push the six black fur clips out using the spudger.
Remove the fur completely.
