Zum Hauptinhalt wechseln
Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement
Was du brauchst
  1. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Back of Phone: Schritt 1, Bild 1 von 1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Remove Battery Pack: Schritt 2, Bild 1 von 2 Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Remove Battery Pack: Schritt 2, Bild 2 von 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Screws: Schritt 3, Bild 1 von 2 Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Screws: Schritt 3, Bild 2 von 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Separate Cases: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Separate Cases: Schritt 5, Bild 1 von 1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, The Front Case: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Replacing Rubber Keys Replacement, Rubber Keys: Schritt 7, Bild 1 von 1
    • The plastic keys are attached to the back side of the front case. To remove the keys, pull the plastic piece out of the front case using the plastic opening tool.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Clemson, Team 13-5, Benson Fall 2013 Mitglied von Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 150
