Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the phone over so that the screen is facing down.
    • Flip the phone over so that the screen is facing down.
  2. Push the gray lever up towards the top of the phone. Pull up on the battery pack and completely separate it from the phone.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Locate the five screws around the back casing. Use a three-prong screw bit to remove all five screws.
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Separate the two cases.
    • Separate the two cases.
  6. Use the plastic opening tool to remove the motherboard from the front case.
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Locate the three screws securing the speaker. Use a Phillips-head screw bit to unscrew the screws
    • Locate the three screws securing the speaker.
    • Use a Phillips-head screw bit to unscrew the screws
  8. Remove the speaker.
    • Remove the speaker.
    • Replace with new speaker.
    • Secure new speaker with screws and reassemble phone.
Abschluss
Austin Shores
301 Reputation
3 Anleitungen geschrieben
Clemson, Team 13-5, Benson Fall 2013 Mitglied von Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 91
