Zum Hauptinhalt wechseln
Sprout Channel Cubby Speaker Replacement
Was du brauchst
  1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: Schritt 1, Bild 1 von 2 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: Schritt 1, Bild 2 von 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Speaker Replacement, Speaker: Schritt 2, Bild 1 von 2 Sprout Channel Cubby Speaker Replacement, Speaker: Schritt 2, Bild 2 von 2
    • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
  3. Sprout Channel Cubby Speaker Replacement: Schritt 3, Bild 1 von 2 Sprout Channel Cubby Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove black tape.
    • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
    • Replace the speaker.
    • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 14-101, Meier Fall 2015 Mitglied von USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - Antwort
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 1,020
