Zum Hauptinhalt wechseln
Sprout Channel Cubby Battery Replacement
Was du brauchst
  1. Sprout Channel Cubby Battery Replacement, Dissasemble the device: Schritt 1, Bild 1 von 2 Sprout Channel Cubby Battery Replacement, Dissasemble the device: Schritt 1, Bild 2 von 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Battery Replacement, Battery: Schritt 2, Bild 1 von 2 Sprout Channel Cubby Battery Replacement, Battery: Schritt 2, Bild 2 von 2
    • Remove the black electrical tape over the ribbon connector.
    • Remove the ribbon connector over the battery.
    • Make sure to be careful of the ribbon connector while working on the device.
  3. Sprout Channel Cubby Battery Replacement: Schritt 3, Bild 1 von 1
    • Next you must heat up the battery to help weaken the adhesive connecting the battery to the device.
  4. Sprout Channel Cubby Battery Replacement: Schritt 4, Bild 1 von 1
    • Once this is done start to pry the battery away from the device carefully. It helps to start at the corners and move inward.
  5. Sprout Channel Cubby Battery Replacement: Schritt 5, Bild 1 von 2 Sprout Channel Cubby Battery Replacement: Schritt 5, Bild 2 von 2
    • Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 14-101, Meier Fall 2015 Mitglied von USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Mitglieder
12 Anleitungen geschrieben
7 Kommentare
Ours is only 6 months old. It only works when it stays plugged in. Battery is bad?
Rachel - Antwort
I had the same problem, only played while plugged in and would not charge.. I found that the battery wires while appearing tight one wire had broken inside the wire insulation at the solder pad on the main board. When I redid the connection it charges, and works well. 8/11/16
larrywb135 -
My grand daughters won't come on, should I take it to an electronic store?. I don't want to try and pry it open, for fear I may make it worse, she loves her tablet, and it is very helpful for her with school, she's had it 2 years and I put it away for about 8 month, for going on line, without permission, I gave it back in Sept. Now its not charging or coming on. Thank you.Deborah
jacksondebo2010 - Antwort
Where can I get a battery?
crzyinind - Antwort
You can get one at Amazon, EBay and more.
Liu Woods -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 3,558
