Einleitung
This disassembly will allow you to replace the batteries, and have access to the internal components of the device.
Was du brauchst
Remove the battery cover by removing the P1 Philips screw.
Remove the 3 AA batteries by hand.
Use Tweezers to remove the side button.
Release the zero insertion force (ZIF) connector.
Pull the ribbon cable away carefully.
With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
2 weitere Personen haben diese Anleitung absolviert.
