Zum Hauptinhalt wechseln
Squier Strat Guitar Pickups Replacement
Was du brauchst
  1. Squier Strat Guitar Pickups Replacement, Pickups: Schritt 1, Bild 1 von 3 Squier Strat Guitar Pickups Replacement, Pickups: Schritt 1, Bild 2 von 3 Squier Strat Guitar Pickups Replacement, Pickups: Schritt 1, Bild 3 von 3
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: Schritt 2, Bild 1 von 2 Squier Strat Guitar Pickups Replacement: Schritt 2, Bild 2 von 2
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: Schritt 3, Bild 1 von 3 Squier Strat Guitar Pickups Replacement: Schritt 3, Bild 2 von 3 Squier Strat Guitar Pickups Replacement: Schritt 3, Bild 3 von 3
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: Schritt 4, Bild 1 von 2 Squier Strat Guitar Pickups Replacement: Schritt 4, Bild 2 von 2
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: Schritt 5, Bild 1 von 2 Squier Strat Guitar Pickups Replacement: Schritt 5, Bild 2 von 2
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: Schritt 6, Bild 1 von 2 Squier Strat Guitar Pickups Replacement: Schritt 6, Bild 2 von 2
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: Schritt 7, Bild 1 von 2 Squier Strat Guitar Pickups Replacement: Schritt 7, Bild 2 von 2
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Ion
479 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 10-5, Green Fall 2015 Mitglied von Cal Poly, Team 10-5, Green Fall 2015
CPSU-GREEN-F15S10G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 7,480
