Zum Hauptinhalt wechseln
Stagg Electro-Acoustic Guitar Strings Replacement
Was du brauchst
  1. Stagg Electro-Acoustic Guitar Strings Replacement, Guitar Strings: Schritt 1, Bild 1 von 1
    • Place the string winder on the tuning key.
  2. Stagg Electro-Acoustic Guitar Strings Replacement: Schritt 2, Bild 1 von 1
    • Wind up the string winder counter-clockwise to loosen the strings.
  3. Stagg Electro-Acoustic Guitar Strings Replacement: Schritt 3, Bild 1 von 1
    • With the string clipper, clip the string under the neck of the guitar.
  4. Stagg Electro-Acoustic Guitar Strings Replacement: Schritt 4, Bild 1 von 1
    • Unwind the string from the machine head and remove it.
  5. Stagg Electro-Acoustic Guitar Strings Replacement: Schritt 5, Bild 1 von 1
    • With the string winder pop the string peg out of its hole.
  6. Stagg Electro-Acoustic Guitar Strings Replacement: Schritt 6, Bild 1 von 1
    • Place the colored circle end of the string in the peg hole.
  7. Stagg Electro-Acoustic Guitar Strings Replacement: Schritt 7, Bild 1 von 1
    • Put the peg in the hole with the string.
    • Pull the string while pushing the pin in.
  8. Stagg Electro-Acoustic Guitar Strings Replacement: Schritt 8, Bild 1 von 1
    • Precut the other side of the string by one and a half machine heads.
  9. Stagg Electro-Acoustic Guitar Strings Replacement: Schritt 9, Bild 1 von 1
    • Thread the string through the peg.
    • Wind the string clockwise from top to bottom with the string winder.
    • Do not overlap the string when winding it.
Abschluss
Repeat steps for each string.
Imanuel Martinez
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 393
