Einleitung
Dog leashes are typically thrown away once parts such as the cord are worn out after extended use. However, it is possible to replace the cord instead of throwing the entire leash away. This guide illustrates how to replace the cord of a Standard 1 Flexi Dog Leash. Since guides to replace the cord of a dog leash are scarce, this repair is helpful to explain this rather unknown procedure.
Note: This fix is meant for dog leashes catered towards smaller to medium sized dogs (less than 46 Ibs).
Was du brauchst
Starting at the lower side of the handle, pry open the leash handle with a metal spudger.
Use a halberd spudger to guide the metal coil out while removing the spool.
Twist the spool out.
Unwind the damaged leash cord.
Keep the cord steady and carefully wrap it around the spool.
Cut the tied end of the damaged leash cord with scissors, or simply untie and remove it.
Insert the new leash cord into the holes and tie the end off with a secure knot.
Align the metal coil end with the peg's groove.
Fit the coiled peg back into the spool.
If the leash repeatedly gets jammed, the new cord getting tangled up inside is the most likely cause. It is best to reopen the leash and untangle the cord, before considering whether a cord different from the guide would suit your leash better.
2 weitere Personen haben diese Anleitung absolviert.
