Zum Hauptinhalt wechseln
Stanley ST-222A-120 Pressure Sensor Replacement
  1. Stanley ST-222A-120 Pressure Sensor Replacement, Pressure Sensor: Schritt 1, Bild 1 von 1
    • Unplug the heater for safety during your repair.
  2. Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 2, Bild 1 von 3 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 2, Bild 2 von 3 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 2, Bild 3 von 3
    • With your hands gently remove the plastic covers on either side of the heater.
  3. Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 3, Bild 1 von 2 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 3, Bild 2 von 2
    • Use your hands to pry apart the plastic halves of the heater to see the internals of the device.
  4. Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 4, Bild 1 von 2 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 4, Bild 2 von 2
    • Locate small pressure sensor replacement and small pressure pin at the bottom of the device.
  5. Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 5, Bild 1 von 2 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 5, Bild 2 von 2
    • Use your hands to help guide the pressure pin back into a position where the replacement plate can slide back onto it.
    • Needle nose pliers may be a good assistant in this situation.
  6. Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 6, Bild 1 von 2 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 6, Bild 2 von 2
    • While the plastic is open hold the pin out with a finger.
    • Line up the pressure plate to the pressure pin.
  7. Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 7, Bild 1 von 2 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 7, Bild 2 von 2
    • Gently put the pressure plate back onto the pressure pin.
  8. Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 8, Bild 1 von 3 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 8, Bild 2 von 3 Stanley ST-222A-120 Pressure Sensor Replacement: Schritt 8, Bild 3 von 3
    • Carefully press the plastic back together.
    • Be conscious not to interrupt the placement of the newly repaired pressure plate.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 517
