Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Use this guide to refill and empty stapler, so you can get back to those TPS reports.
  1. Be careful while handling staples or any sharp object in general. Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
    • Be careful while handling staples or any sharp object in general.
    • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
    • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
  2. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  3. Get a cluster of staples and carefully place it in the carrier. Make sure there is enough room for the pusher to contact the staples.
    • Get a cluster of staples and carefully place it in the carrier.
    • Make sure there is enough room for the pusher to contact the staples.
    • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
  4. Don’t staple your hand, or anyone else for that matter.
    • Don’t staple your hand, or anyone else for that matter.
    • Congratulations! You have successfully replaced staples in your stapler.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Sequoia Equities
201 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 27
Letzten 30 Tage: 76
Insgesamt: 9,125
