Einleitung
If your stapler isn’t stapling, then there’s a good chance the spring is damaged. This guide's purpose is to assist users in replacing the stapler spring.
If you don’t replace the spring yourself, you’ll either have a broken stapler cluttering up your work space or will end up buying a new stapler altogether.
Before using this guide, check to see if the spring itself is damaged. Another possibility of a stapler not working is a staple jam. Be careful when handling the stapler, since it’s possible to staple yourself. We recommend that you empty the staples beforehand.
Was du brauchst
Press down on the metal part inside the handle with your thumbs until it will not go down anymore.
Thread the other end of the new spring through the top rectangular hole toward the back.
Thread the new spring through the bottom hole, bringing the end of spring toward you.
Press the metal part down with your thumbs until it aligns with the hammer's hole.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
Just what I needed. Thank you! Super clear
Can I replace the black rubber piece that goes on my swingling desk top stapler 70 sheet it came off and my dog chewed it up.
fron this sale ski o donde venden los repuestos de esta engrapadora en Venezuela gran caracas
Romulo -
Wie funktioniert das für große Klammermaschinen wie dieser hier?
Ihr Artikel war sehr leicht zu verstehen und ich habe es geschafft, vielen Dank gacha life!
