Einleitung
This is a prerequisite guide for replacing all of the Staples 34462 Electric Pencil Sharpener's parts. Or maybe your cover is just cosmetically damaged and you want to replace it. Follow the steps below to remove the cover for replacement.
Was du brauchst
Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
Using the plastic opening tool, remove the back plastic feet.
After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
