Zum Hauptinhalt wechseln
Starbucks Barista Steam Wand replacement or cleaning
Was du brauchst
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: Schritt 1, Bild 1 von 1
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: Schritt 2, Bild 1 von 2 Starbucks Barista Steam Wand replacement or cleaning: Schritt 2, Bild 2 von 2
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
David
748 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-42, Regan Winter 2011 Mitglied von Cal Poly, Team 4-42, Regan Winter 2011
CPSU-REGAN-W11S4G42
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 15,882
