Einleitung
The portafilter pressurizes the water through the coffee filter to produce the espresso. If the portafilter is dirty or malfunctioning it could result in weak coffee, or no coffee at all. This guide will help you disassemble, clean and reassemble your portafilter.
Was du brauchst
Turn the portafilter handle to the left to remove it from the machine.
Flip the portafilter over so the bottom with the 3 screws faces up.
Before beginning, make a small, neat "scribe" mark on both the bottom edge of the plastic basket and, right next to it, the top of the metal basket. This match-marks these two pieces. Unscrew and remove the 3 phillips-head screws.
Lift off the plastic handle assembly, exposing the internal pressure system and two springs. Take note of the handle's orientation in relation to the metal piece as it will need to be re-attached in exactly the same position to function correctly.
Take note of the spring's placement, then carefully remove and set them aside.
Clean the pressure assembly with a citrus-based cleaner and a brush, making sure to get under the hinged needle valve. Rinse well, then replace the springs.
Reattach the handle assembly with the 3 phillips-head screws. If assembled correctly the handle should pivot slightly in relation to the metal portion, than spring back when released.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
13 Kommentare
any luck on replacing the gasket?
Where can I purchase a portafilter for this? johnbrosnan2010@yahoo.com
i just did this and it worked. my problem was i kept thinking it wasnt working bc the water kept flowing out of the top and not going through the two holes into the cup. I figured out it needs the coffe grounds in there to actually work! thanks!
I am still having a problem with it Brewing you can tell it wants to but it won't come through sometimes a little bit will any suggestions.
