Zum Hauptinhalt wechseln
Steam Link Disassembly
Was du brauchst
  1. Steam Link Disassembly, Starting up: Schritt 1, Bild 1 von 2 Steam Link Disassembly, Starting up: Schritt 1, Bild 2 von 2
    • Start by unplugging your device
    • Power cord
    • Ethernet
    • HDMI
  2. Steam Link Disassembly, Removing the rubber bottom: Schritt 2, Bild 1 von 2 Steam Link Disassembly, Removing the rubber bottom: Schritt 2, Bild 2 von 2
    • Start by removing the rubber bottom using the Guitar Pick or the Jimmy
    • The first time, the adhesive may be difficult to remove
  3. Steam Link Disassembly, Removing the screws: Schritt 3, Bild 1 von 2 Steam Link Disassembly, Removing the screws: Schritt 3, Bild 2 von 2
    • Remove the screws using a Torxx 6 bit
  4. Steam Link Disassembly, Opening the lid: Schritt 4, Bild 1 von 2 Steam Link Disassembly, Opening the lid: Schritt 4, Bild 2 von 2
    • Open-up the bottom lid using guitar pics
    • The first time you open it, it might be difficult to open. Start by reaching the rounded, bottom-right corner
  5. Steam Link Disassembly, Main board inspection: Schritt 5, Bild 1 von 2 Steam Link Disassembly, Main board inspection: Schritt 5, Bild 2 von 2
    • Marvel ArmV7 CPU
    • Vivante GC1000 GPU
Abschluss
To reassemble your device, follow the steps in the opposite order
8 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
bonjour esque cette carte peu servire comme raspberry merci
thesmoking gta - Antwort
Non, seule une image signée par Valve peut être lancée. Elle a un accès SSH comme indiqué sur la page du SDK cependant. Notez qu'elle n'est plus fabriquée depuis décembre, donc elle n'est plus vraiment disponible.
Jorys Paulin (Jorys_Paulin) -
Somewhat unworthy Teardown. Naming the CPU brand wrong and not giving any relevant information like schematics or ICs used. THIS is by far better: https://www.allaboutcircuits.com/news/te...
EDIT: Oh, it is a community post, sry. But more information would be nice. E.g. where is the massive heat sink? There are lots of parts missing.
Jan Seewald - Antwort
Hello, this is my first (and only) teardown. I made it just for fun, really. I opened my Steam Link once and then decided to put it on the internet, because I found they weren’t that much photos of it around.
The heat sink is a large piece of aluminum, and now I realize I forgot to add it, my mistake.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 70
Insgesamt: 4,740
