Zum Hauptinhalt wechseln
SteelSeries Apex 64145 USB Port Connector Replacement
Was du brauchst
  1. SteelSeries Apex 64145 USB Port Connector Replacement, Gel Membrane: Schritt 1, Bild 1 von 1
    • Unplug the keyboard from the computer.
  2. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
  3. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 3, Bild 1 von 1
    • Pry open the back of the keyboard.
  4. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 4, Bild 1 von 2 SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 4, Bild 2 von 2
    • Remove the gel membrane.
  5. SteelSeries Apex 64145 USB Port Connector Replacement, LED: Schritt 5, Bild 1 von 2 SteelSeries Apex 64145 USB Port Connector Replacement, LED: Schritt 5, Bild 2 von 2
    • Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
  6. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 6, Bild 1 von 1
    • Flip the chip slightly in order to remove the sheets.
  7. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 7, Bild 1 von 1
    • Remove the sheets.
  8. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 8, Bild 1 von 2 SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
  9. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 9, Bild 1 von 1
    • Remove the plastic panel and the white sheet.
  10. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 10, Bild 1 von 3 SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 10, Bild 2 von 3 SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 10, Bild 3 von 3
    • Unplug the wires connected to the LEDs.
  11. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 11, Bild 1 von 2 SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 11, Bild 2 von 2
    • Remove the LEDs.
  12. SteelSeries Apex 64145 USB Port Connector Replacement, USB Port Connector: Schritt 12, Bild 1 von 1
    • Unscrew the two 4.5 mm silver Phillips #1 screws that hold the USB port connector.
  13. SteelSeries Apex 64145 USB Port Connector Replacement: Schritt 13, Bild 1 von 1
    • Unplug the wires and remove the USB port connector.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G1, Nance Spring 2017 Mitglied von USF Tampa, Team S1-G1, Nance Spring 2017
USFT-NANCE-S17S1G1
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
the 2 usb in the keyboard what amp are they running on.. 500mA ? I hope for 1500-2000 mA
And what standard are they ? USB3 ??
Simon Sundström - Antwort
can the other part be replaced too. like the power board ?
i think i have a powerboard problem and if I can replace it that would be awesome, as I love my keyboard and im
very very attached to it. I was playing a video game, nothing too harsh , and the lights went out and poof it never came back. never had a problem with this keyboard until 2 and a 1/2 years later that it did this. Its in a non-smoking room and gaming studio always kept very clean.
I would love to fix it to bring it back to life.
Twsted - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 57
Insgesamt: 3,040
